6-Foot Premium Optical Toslink Cable 8.0mm with Metal Fancy Connector
4.0
based on 5 reviews
from
Ratings Distribution
5 star
3
4 star
1
3 star
0
2 star
0
1 star
1
Category Average
4.1
Pros
  • Rugged (3)
  • Good length (2)
  • Consistent performance (1)
  • Easy setup (1)
  • Easy to use (1)
  • Excellent sonics (1)
  • Versatile (1)
See less See more
Cons
  • Will not connect (1)
Best Uses
  • Any audio toslink connect (1)
  • Upgrade (1)
6-Foot Premium Optical Toslink Cable 8.0mm with Metal Fancy Connector Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 6-Foot Premium Optical Toslink Cable 8.0mm with Metal Fancy Connector
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 23, 2008
6-Foot Premium Optical Toslink Cable 8.0mm with Metal Fancy Connector Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
Superior Audio Performance
5.0
    Pros
  • Excellent sonics
  • Rugged
    Cons
  • None
    Best Uses
  • Any audio Toslink connect
"This is one outstanding premium Toslink audio cable. I bought all 3 lengths and each performs extremely well. Staying below 15' in length ensures no audio worries in terms of distance. I use these cables to connect an CD player to my Sony Receiver as well as to connect a HD-DVD player. Sound quality …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the 6-Foot Premium Optical Toslink Cable 8.0mm with Metal Fancy Connector helpful to you?
Feb 3 2008
Bob
Seattle, WA
I am:
  • Professional
Reviewed at:
[0 of 1 customers found this review helpful]
GREAT CONNECTOR
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • None
"I gave a previous negative review which was wrong. I did not know that there is a soft plastic guard over the end of the connector which has to be removed before it can be used.
The connection makes a perfect fit. I like the protector covering the fiberoptic cable. "
 Report Abuse  (0)  (1)  0 comments
Jan 12 2008
Jimbo
Clemson, SC
I am:
  • Gearhead
Reviewed at:
Toslink Cable
1.0
    Pros
  • None
    Cons
  • Will not connect
    Best Uses
  • None
"This Toslink will not connect to either my Sony Amp or to the optical output of my Asus motherboard. I have another Toslink cable that makes a perfect connection. There must be different versions of Toslink. I thought it was a standard. "
Nov 13 2007
Jim
SC
I am:
  • Gearhead
Reviewed at:
Very good cable for the price
4.0
    Pros
  • Good Length
  • Rugged
    Cons
  • None
    Best Uses
  • None
"Very good cable at a very good price. "
Feb 13 2008
Blu-Ray all the way
Turlock, CA
I am:
  • Practical
  • Tech Savvy
Reviewed at:
works good
5.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Upgrade
"audio works great with it "
Jul 23 2008
bob
georgia
I am:
  • Technically Challenged
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
