2.4V 800mAh NiCd - Nicad Cell Or Pack Of Cells
4.4
based on 23 reviews
Ratings Distribution
5 star
16
4 star
4
3 star
1
2 star
1
1 star
1
Category Average
3.9
Pros
  • Charges quickly (13)
  • Reliable (10)
  • Long lasting (8)
  • Powerful (8)
  • Good value (2)
  • It does the job (1)
  • Razor runs like new (1)
  • Received it (1)
See less See more
Cons
  • High cost for them (1)
  • Short life (1)
  • So far - no cons (1)
  • Tabs should not be taped (1)
  • Time will tell (1)
Best Uses
  • Portable electronics (9)
  • Having around the house (7)
  • Travel (6)
  • Electric razor (1)
  • Electric shaver (1)
  • High-end equipment (1)
  • Remington shaver (1)
  • Shavers (1)
Provided by Interstate Batteries
2.4V 800mAh NiCd NICKEL CADMIUM
Specification Description
UPC 656489046932
Chemistry NICKEL CADMIUM
Height 1.90 inches
Length 1.90 inches
Milliamp Hours 800.00
Termination WITH SOLDER TABS
Voltage 2.40
Weight .3000000 pounds
Width .55 inches
2.4V 800mAh NiCd - Nicad Cell Or Pack Of Cells Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 2.4V 800mAh NiCd - Nicad Cell Or Pack Of Cells
See all eBay results
  at eBay.com
Product Reviews
Last update: Mar 14, 2009
2.4V 800mAh NiCd - Nicad Cell Or Pack Of Cells Reviews
Most helpful positive review
Most helpful negative review
4.0
Excellent product
"This battery pack replaced a dead one in a Norelco razor. Cellophane tape protecting the tabs was a nuisance to remove and tape residue may have made soldering one tab difficult. A small rubber band might work better if the cost difference doesn't prohibit this. I think a small hole in each tab would useful. I'd use a flimsier plastic bag that's easier to open. I like minimal packing with as little waste as po..." Read Full Review »
Dec 13, 2007 by Jim
See more positive 2.4V 800mAh NiCd - Nicad Cell Or Pack Of Cells reviews
2.0
Battery for Shaver
"It is not the issue of the batteries working as they work fine, but paying that much money for TWO batteries is out of this world. I thought that they were 2.4 volts each not just 1.2 volts each, that price is out of this world...." Read Full Review »
Dec 22, 2007 by Trump
See more negative 2.4V 800mAh NiCd - Nicad Cell Or Pack Of Cells reviews
Displaying 1 - 5 of 23 Reviews
Show
Sort by
Excellent product
4.0
    Pros
  • It does the job
    Cons
    Best Uses
  • Portable Electronics
"This battery pack replaced a dead one in a Norelco razor. Cellophane tape protecting the tabs was a nuisance to remove and tape residue may have made soldering one tab difficult. A small rubber band might work better if the cost difference doesn't prohibit this. I think a small hole in each tab wou …"  Read Full Review »
Was this Battery review on the 2.4V 800mAh NiCd - Nicad Cell Or Pack Of Cells helpful to you?
Dec 13 2007
Jim
Smithfield, VA
I am:
  • Value Oriented
Reviewed at:
Works Better Than I Hoped For
5.0
    Pros
  • Long Lasting
    Cons
  • None
    Best Uses
  • Travel
"Was quite hesitant not being sure these were going to do the trick, but paid the price installed a set in my Norelco 5801XL shaver, gave them a full charge and couldn't be more pleased. Now goes a month between charges (was down to every 3-4 days before and can't even remember the original batteries …"  Read Full Review »
Mar 14 2009
roppd
Freehold, NJ
I am:
  • Value Oriented
Reviewed at:
Great for older Remington Shavers!
5.0
    Pros
  • Charges Quickly
  • Long Lasting
  • Powerful
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Shavers
"Worked wonders on my older shaver (Remington DT-42). I had other alternatives but they were less than the 800mAh I needed for my shaver. [...] On average, the service shops were asking $30-$35 to replace the rechargeable battery pack but as a DIY'er and under [$] total, it was done! "
Oct 3 2007
Felix
Miami, FL
I am:
  • Value Oriented
Reviewed at:
[2 of 3 customers found this review helpful]
Great replacement for my shaver
5.0
    Pros
  • Charges Quickly
  • Long Lasting
  • Powerful
    Cons
  • None
    Best Uses
  • Having Around The House
  • Travel
"Bought this as a replacement for a Norelco 4845XL shaver I bought on clearance 7 years ago. this battery pack is a perfect fit and works just as well as the original battery. Replacement was easy, using only a soldering iron and a "solder sucker". "
 Report Abuse  (2)  (1)  0 comments
Dec 21 2007
Bradscope
Cookeville TN
I am:
  • Quality Oriented
Reviewed at:
Battery for Shaver
2.0
    Pros
  • None
    Cons
  • High Cost for them
    Best Uses
"It is not the issue of the batteries working as they work fine, but paying that much money for TWO batteries is out of this world. I thought that they were 2.4 volts each not just 1.2 volts each, that price is out of this world. "
Dec 22 2007
Trump
I am:
  • Value Oriented
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
