12 foot Molded Digital Optical Audio TosLink Cable
4.9
based on 9 reviews
Ratings Distribution
5 star
8
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.3
Provided by Overstock.com
*Toslink Digital Audio Cable provides you the cleanest possible signal, even at extreme volume levels *Cables use 1mm low-loss core, low-jitter synthetic fiber and heavy metal connectors to dampen vibration, giving you the ultimate listening experience *Optical cables transfer the signal using light; completely eliminating any chance for RFI, EMI or ground loop interference *Stylish PVC HEAVY 5.0mm JACKET helps prevent cable damage and adds flexibility and durability *Moulded strain reliefs reduce stress where cable and connectors meet *Gold-plated ferrule prevents corrosion and provides for maximum protection of the fiber tip *Precesion polished fiber tips for maximum signal transfer (includes tip protectors) *Connect to your DVD, CD, Mini Disc, DAT other digital audio equipment for clear, full and richly detailed sound *Connectors: Toslink Male to Toslink Male *Cable Length: 12 feet / 3.7m *OD 5.0 *Designed for CD, D/A Converters, Dolby Digital DTS Surround sound receivers, DVD, MiniDisk players and recorders, Pro Audio cards, etc. *Compatible with: ADAT, DAW, Dolby Digital, DTS devices with TosLink interface
12 foot Molded Digital Optical Audio TosLink Cable Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 12 foot Molded Digital Optical Audio TosLink Cable
See all eBay results
  at eBay.com
Product Reviews
Last update: Nov 13, 2008
12 foot Molded Digital Optical Audio TosLink Cable Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
5.0
"The fit and function of this cable is excellent! Outside of a break in the physical optical media (which happens to be plastic I think) and if the manufacturer molds the ends correctly (which they did) this cable will do all that it was made to do. "
Was this Electronics review on the 12 foot Molded Digital Optical Audio TosLink Cable helpful to you?
Apr 10 2008
EBJones
Oregon
Reviewed at:
Fiber optic cable
5.0
"This product does what it is designed to do. If you have a receiver that accepts optical inputs for audio , it would be to your advantage to use optical cables. This eliminates all the RCA audio connections and clutter.
D. "
May 6 2008
D2008
Midwest
Reviewed at:
Recommend
5.0
"I highly recommend this product to all who want the best for a lot less. I use this cable for my surround sound system that I bought from overstock.com and it works great. "
Jun 24 2008
Louie70x7
Los Angeles, CA
Reviewed at:
works great!
5.0
"cable arrived quickly and was easy to connect. much less expensive than any of the local stores. it improved the sound of my home theater when connected with satellite box. "
Apr 5 2008
jacobb
West Virginia
Reviewed at:
Great Sound at Affordable Price
5.0
"The cable is easy to hook up. It provides a pure digital sound which is prefect for a HDTV to Reciever hookup. "
May 21 2008
KingofWatches
Wichita, KS
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
